Search found 27 matches
- Sat Mar 26, 2022 5:39 pm
- Forum: The Lounge
- Topic: Historic Car Tax - E-petition.
Re: Historic Car Tax - E-petition.
Excellent idea after 20 1/2 price tax.
- Fri Mar 25, 2022 2:03 pm
- Topic: Timing belt on 216 gsi 1991
Re: Timing belt on 216 gsi 1991
Thank you for advice.
- Mon Mar 21, 2022 7:36 pm
Re: Timing belt on 216 rover engine 1.6
1998 216 1.6 petrol is timing belt hard to do on the rover engine.
- Mon Mar 21, 2022 7:30 pm
- Forum: Introductions
- Topic: Hi everyone.
Re: Hi everyone.
Hi welcome good luck when you get your new rover.
- Mon Mar 14, 2022 11:23 am
- Topic: Bleeding hood pump after fitting new one
Re: Bleeding hood pump after fitting new one
Thank you , one or 2 more thing if possible my black cloth lining just above head cloth is ragged at edges rest is good , I was thinking or renewing the edges by over coving with black material to match using spray glue , but where or how far out should inner materials come too , on each side above ...
- Sun Mar 13, 2022 3:29 pm
You mean cable ties , type of thing or ?
Thanks
Thanks
- Sat Mar 12, 2022 6:13 pm
- Topic: Clamp that adjusts steering column can it be tightened
Hi in my 98 216 the lever to adjust steering wheel up down etc is quite slack can you tighten these up. I could take cowling etc off to check but thought I would ask first in case someone else has done this. Thanks.
Stevie.
Stevie.
- Sat Mar 12, 2022 6:07 pm
Got the pump bled today as suggested by 961tat lifting up and down manually, everything worked to plan , just couple of the brackets that hold head liner were seized and not turning on the round bar also broke couple of the we screws but going to put rivet in them 2 but at least they are all nice an...
- Thu Mar 10, 2022 10:34 am
- Topic: Hi Folks!
Re: Hi Folks!
Very nice looking car. Enjoy
- Tue Mar 08, 2022 1:05 pm
- Topic: Looking for dash clock 8 pin
Re: Looking for dash clock 8 pin
Just in case it helps someone else the 8 pin socket of my car plugs straight into a 4 pin clock and works no problem, it will only show time , not radio but that did not matter to me as have radio / cd fitted so mine did not show stations any how. For me a 4 pin clock £10 a 8 pin clock £159 used , s...
