Search found 12 matches
- Wed Dec 06, 2023 6:35 pm
- Topic: Advice on Rear Heated Window not Working
Re: Advice on Rear Heated Window not Working
Hi thanks for your reply! I was being dense and did not check the fuse! The fuse was burnt out so I will replace that and hopefully that will fix this issue. For anyone interested it is Fuse 23 if you look up the diagram, and it is a 25 amp fuse. Should have checked the obvious first but it slipped ...
- Mon Dec 04, 2023 1:12 pm
Hi All hope you can help I have recently replaced the tailgate wiring loom on my rover 216. It went succesfully thanks to the many guides on here, and my top brake light and rear windscreen wiper are working fine. Unfortunately the Rear Heated Window does not seem to be working. It was still working...
- Wed Nov 15, 2023 3:54 pm
- Topic: I've just bought some new wheels for my Rover 216.
Re: I've just bought some new wheels for my Rover 216.
or does it not apply because the wheels are not for this car originally.. 100% correct. The Cosmos wheels were fitted as standard to some versions of the Rover 45, so having looked at Rimmer's page for the 400/45 range I would suggest that these are the nuts to go for: https://rimmerbros.com/Item--...
- Tue Nov 14, 2023 9:20 pm
You will need some wheel nuts for alloy wheels - still available from Rimmers. awesome, thanks for letting me know! cheers There are 2 options; > Models with Alloy wheels to VIN AD83100 >Models with Alloy wheels from VIN AD83101 my car says : e11*93/81*0016*06 SARRFMWZFYD459143 I would assume the f...
May I ask from which car these alloys are taken? Asking because of MG centre caps. The guy I bought them from said he had them on a MG ZR . The centre caps say MG but I think they can be replaced. The rims themselves were originally Rover as that is on the back of them. https://i.postimg.cc/rpsByxW...
- Tue Nov 14, 2023 5:34 pm
Hi Everyone I am dead chuffed and well excited so I had to make a post! I nabbed some Cosmos alloys on ebay for a 1er and drove up from Gloucestershire to Birmingham today to collect them, they are in pretty good nick and I can't wait to get them on the old girl! Will have to take out the MG centre ...
- Sat Nov 11, 2023 12:41 pm
- Topic: Help Choosing Correct Oil Seal
Re: Help Choosing Correct Oil Seal
Thanks very much for your help!
- Thu Nov 09, 2023 9:19 pm
Hi Everyone I am replacing my RH front driveshaft and was hoping someone could help me identify and purchase the correct oil seal for my car. my car is Rover 216 Reg is V468 FES e11*93/81*0016*06 SARRFMWZFYD459143 There are a few different options on Rimmer bros and I don't want to purchase the wron...
- Thu Jun 29, 2023 6:19 am
- Topic: K16 Engine Cambelt Correct Tension ??
Hi All, hope everyone is well. I have just replaced cambelt and water pump on my Rover 216 with the K16 Engine. I saw a video saying how to set the correct tension on the automatic tensioner. The vid said to align the end of the spring with the metal notch, and when they are lined up facing eachothe...
- Mon Jun 12, 2023 7:13 pm
- Topic: Rover 216 Tailgate Wiring Loom VIN number
Re: Rover 216 Tailgate Wiring Loom VIN number
Great Stuff, Thanks for Your Help!
