The New MOT Test
The New MOT Test
A new set of regulations are coming into force post 20th May. There is one set of emissions tests foe vehicles registered between 1st Aug 1992 and Aug 1995. I have just been told that these test's are going to be more stringent than before? Non cat R8's between Oct 89 and July 31st 92 are thus subject to a less stringent test?
Any MOT Testers in the club that would like to add their two pennyworth? :)
Re: The New MOT Test
Post by Hammond »
I also heard that it is now expected that the minor issues (what they're now called) are to be done before the next MOT is due :o
45 Auto 24v V6 Connoisseur Wedgewood Blue
216GSi Auto Gold
414Si Tahiti Blue
414SEi Bermuda Blue
214SEi Nightfire Red
214i Sprint Flame Red
416GTi Auto Diamond White
214SEi Tahiti Blue
416Si Tahiti Blue
Montegoman
Post by Montegoman »
I have asked Howard to write an article on the new MOT regs for the next edition of "The Viking".
214GSi G79XKV (R8 No.1) (9 yrs of ownership)
75 2.5 Connoisseur SE Tourer (20 yrs of ownership)
JOHNDQ
Post by JOHNDQ »
Im a tester the emissions are for diesel cars. Basically you have to use the emissions on the vin plate rather than the old emissions limit i.e the old limit for say a turbo Euro 4 car was 1.5m-1..... that was that easy. But now you have to look for the manufacturers plate value on the vin plate (if it has one) and go off that value. Most are 0.50m-1 so if your car was putting out 0.60m-1 it would now fail were as before would have been a easy pass
214 Sprint track car
216 GTi track car
216 GTi DOHC
JOHNDQ
Post by JOHNDQ »
Hammond wrote: Fri May 04, 2018 5:49 pm I also heard that it is now expected that the minor issues (what they're now called) are to be done before the next MOT is due :o
No "minor" is the new word for the old "advise" so will still be noted on the mot paper work but its down to you what you do about it
216 GTi track car
216 GTi DOHC
Montegoman
Although the new regs don't come in until 20th May I was given a new style certificate for my 75 MOTd today.
JOHNDQ
Post by JOHNDQ »
Yes they came in early about 3 weeks ago
216 GTi track car
216 GTi DOHC
Will_216GSi
Post by Will_216GSi »
Mr Teddy Bear wrote: Fri May 04, 2018 5:01 pm A new set of regulations are coming into force post 20th May. There is one set of emissions tests foe vehicles registered between 1st Aug 1992 and Aug 1995. I have just been told that these test's are going to be more stringent than before? Non cat R8's between Oct 89 and July 31st 92 are thus subject to a less stringent test?
Wew my car just scrapes though as before July 92... I feel lucky! No cat... Just...
I am pleased to say that every L-series diesel I have owned has always gone straight through the emissions test with no bother (is it called a'fast pass?'). Hopefully that will continue under the new tests.
A friend of mine owns a ZR 115 diesel and regularly travels to Europe: He managed to get it certified in Germany as Euro 4 compliant so that he has been able to take it into cities such as Berlin. Perhaps if Rover had survived another year or two, the L-series may have got Euro 4 without the need for a particulate filter, just as Honda did with the 2.2 i-CDTi.
Do any of our R8 diesel owners with the Peugeot engine have any problems getting their cars through the MoT emissions test at the moment?
Julesmat50
Post by Julesmat50 »
220 GSi turbo wrote: Fri May 04, 2018 7:00 pmDo any of our R8 diesel owners with the Peugeot engine have any problems getting their cars through the MoT emissions test at the moment?
It will be interesting to see what happens at the next MoT, which is due in a couple of months time. Up until now, both of my Peugeot TD's have passed whatever the current emissions tests were, with no issues. My first one had over 210,000 miles on when it passed it's last MoT and my current one has over 110,000. There is very little that can alter the emissions on this basic diesel engine other than faulty/worn injectors or a dirty air filter as it is totally mechanical. They don't have a manufacturers "emissions" on the VIN plate, the design is pre all those requirements (engine manufactured between 1982-2001).
According to the DVLA's own information, the new regs only apply to a new diesel or a car with a DPF, viz:-
There will be stricter limits for emissions from diesel cars with a diesel particulate filter (DPF).
You’ll test vehicles to the manufacturer’s plate value (when present), or a new lower default limit for newer vehicles.
The Peugeot XUD7TE and XUD9A engines fitted to the R8 were never build with a DPF as far as I can tell (the Haynes manual of these engines doesn't mention replacing of a DPF in the annual maintenance guides) so it looks like the new rules won't apply as far as the DPF is concerned. That said, if you "can see smoke of any colour coming from the exhaust" then it will fail.
