Sd3 216 correct spark plugs
Liam.d
Post by Liam.d »
Hello, would someone be so kind to tell me the correct spark plugs that are fitted to my 216s. Iv noticed that on number 4 the 16mm fitting is so close to the head casting it’s almost impossible to get on it with anything. Cheeeers
Re: Sd3 216 correct spark plugs
I have a 1996 Unipart catalogue that lists GSP4562 as the standard fit, with GSP6662 as the 'dual copper upgrade'.
Equivalents include:
Bosch FR7DC, F7DC and F8DC.
Champion C9YC, C9YCC, RC9YC and RC9YCC.
NGK BCPR6ES, BCP6ES and BKR6E.
Liam.d
Post by Liam.d »
Ahh thank you ever so much,I’ll get some from my local motor factor, also I don’t suppose you know of any good carbs for sale or if they can be rebuilt as mine is a pain it’s still on the auto choke and that can be a pain also it’s running lean at 0.50 CO at idle, I’m led to believe they should be between 1 and 1.5% CO at idle which it won’t adjust to, Iv replaced all the rubber hoses etc and even the temp senders so I’d like to try another carb
Post by Paul_1978_yorks »
Get iridium plugs if you can - I’ve always found my engine to run so much smoother with them in.
JEASPEKE
Post by JEASPEKE »
Me too, I fitted Iridium plugs (to 216GTi Honda DOHC) and immediately noticed better starting, better acceleration, and smoother running, with no issues at MOT time with the emissions.
These plugs last 100k miles in Honda's view. Also used in F1 cars. Give them a try.
John
Liverpoolman1
Post by Liverpoolman1 »
Are the Iridium plugs more expensive than the standard ones, and, if so, by how much?
7
I’ve only looked for Bosch but I can’t see an iridium plug that would fit your car, but can see a nickel plug under ref FR7DCX.
If you have time to look at other brands, eg NGK, they might do a a suitable Iridium Plug.
If I remember rightly the last set of iridiums I bought were about £36, but well worth the investment, and they last much longer as well as running smoother.
EDIT: I think the equivalent NGK is BKR6EIX
Liam.d
Post by Liam.d »
Thank you, ngk do the iridium ones readily available
