Sealing tailgate hinges after adjustment
ashy90
Post by ashy90 »
Can I loosen the hinges to adjust tailgate and then re-seal around the hinges? Or do they have to be fully removed to apply sealant between the hinge and car body?
Re: Sealing tailgate hinges after adjustment
Any attempt at sealing would be better than none, but ideally the hinges should be lifted so that you can get sealant underneath them and then squeeze it out as the hinges are tightened.
MatthewL
Post by MatthewL »
It’s interesting that after multiple leak fixes, I think this might be the dryer of the leak in my car. I did use a little Sikaflex but not much to put the hinges plus factory fitted shims back in - maybe not enough and maybe more between the shims us needed? What sealant do you guys use?
JOHNDQ
Post by JOHNDQ »
Tiger seal or panel seam sealer
214 Sprint track car
216 GTi track car
216 GTi DOHC
