My 45 cut out at speed (80 plus) for a second then picked up again for about twenty seconds. Again it lurched and then a second later ran fine. If not driven quite so hard, it was fine and got me home (about thirty miles). It did start to do it again when near home on A roads at lower speeds (50mph).
It ran okay locally and I nursed it for a few days until it started to cut out more frequently and a lower engine speed.
I have the following fault codes:
P1335 - Fuel Pump Position Sensor Malfunction
P0216 - Timing Device Position Governing
And now the questions. Is the second fault (P0216) a result of the Sensor (P1335) being knackered....almost like a default setting or is it the other way round in that there is something more terminally wrong which has caused these faults.
I think I am asking do I start with a new Fuel Pump Sensor and see what happens or will changing that not cure the second fault?
And of course, I'll take any other advice or hypothesis you may have. I am looking to have a go at putting it right myself but I wouldn't even class myself as a keen amateur......more a tight fisted chap who doesn't want to scrap the car. Thanks for having a look.
Car is 107k miles, and regularly serviced including new diesel filter about 10K ago.
2.0 L Series Diesel - Fuel Pump
redandwhitE
1995 416 SLi (Saloon & Tourer)
2003 45 Imp Diesel (plus spares car)
2004 45 imp Petrol
1993 416 GSi - spares
1972 Mercedes 350 SL
1998 Audi Cabriolet
2004 45 imp Petrol
1998 Audi Cabriolet
