Honda SOHC & DOHC Engines
Post by Paul_1978_yorks »
I understand that my forthcoming Rover 216 will ether have a DOHC or SOHC engine in.
What is the difference and how will I be able to tell which one I've got?
Re: Honda SOHC & DOHC Engines
Honda twin cam
Honda sohc
rover 216 k-series
In the pics above, none have ALB or ABS fitted.
Hopefully yours will look like that!
The SOHC has a non-standard, cone air filter fitted - the standard set up looks the same as in the DOHC pic.
not as easy to find engine pics like it used to be :angel
carl747
Post by carl747 »
The 1st picture of the k series is a 1.4 not 1.6
How sad am I *laughs*
64 1/2 Ford Mustang 289 V8
Past
94 Rover Metro Gti
03 MG ZT
89 Austin Metro 998
92 Rover 216 GTi Twin cam (Roversport Kitted) Twice :laughing2
97 Rover 218 VVC Cabriolet the original VVC Cabby (Roversport Kitted)
carl747 wrote:The 1st picture of the k series is a 1.4 not 1.6
Very - Did you tell by the engine mount?
Cheers guys - I've seen a pic of the engine and it's a Honda SOHC. That's fine by me as I drive like an old man anyway (even though I'm not!)
How can I identify this ABS unit then, and whether mine has one or not?
Paul_1978_yorks wrote:How can I identify this ABS unit then, and whether mine has one or not?
The most obvious sign is that there is a big hydraulic unit with a second brake fluid reservoir sitting just rearwards of the battery - you won't miss it!
The brake servo, master cylinder, brake valve and engine-bay brake pipes are different too.
Thought I had a photo handy which would show it but I don't - I'll have a look in the manual.
99% chance that yours won't have it :laughing2
Thanks for all your help John! Getting the train to pick the car up and got a 4 hour drive back in it. I'll no doubt be taking some pics either on the journey when I stop for a brew or on Friday morning.
Catch you later :-)
