Rev limiter 216 honda engine
rwd fan 2
Post by rwd fan 2 »
Hi all,is there an easy to stop this cutting in other than taking my foot off the gas *laughs*,i'm just after a few extra revs,thanks.
Clawjaw
Re: Rev limiter 216 honda engine
Post by Clawjaw »
rev limiter!? :S
MartynG
Post by MartynG »
No as far as I'm aware. It is there to protect the engine, So I'd leave it alone. If you want abit of extra power why not fit a stainless exhaust which will make it breath better and add a K&N induction kit or panel filter (Which goes in the original air box) these will make it sound and run better and will add a few extra bhp. :)
rwd fan 2
Post by rwd fan 2 »
I use my rovers for oval racing so engine life is'nt to important,does anyone know how the limiter works exactly? cuts in at about 7000 revs i think.
Post by E_T_V »
The rev limiter will be coded into the ECU I believe.
It will probably cut the spark rather than the fuel, but it could do either or even both.
As it is a honda lump the honda boys will probably be able to rechip/remap the ecu to alter or remove the rev limiter. I've not looked into it in detail though.
rwd fan 2
Post by rwd fan 2 »
Many thanks for your replys ta.
