Clock Light
Smithy
Club President
Clock Light
Post by Smithy »
Common fault on the Rover 200/400, my old 200 had it as well. The backlight has gone on the clock.
Does anyone know what size the replacement bulb is for them and where I can get one from?
216GSi
Post by 216GSi »
All it says on the back of mine is PHILLIPS 12/1.2
Don't worry - I didn't rip it out to check, I've got three clocks (and wood surround) in the boot that I've got from scrappies!
1995 Rover 220 Coupe turbo (62k)
Devon-rover
Post by Devon-rover »
They are about £6.00 from X-Part. Had to have one lately.
Cheers
Chris
mach1rob
Post by mach1rob »
OUCH! Any decent car shop should have them for pence, just a bog standard twist lock bulb same as this one :)
http://www.dashlights.co.uk/cart.php?ta ... ory_id=276
Devon-rover
£0.89 I feel sick! X-Part want our business at what expence Rip-off sods
Cheesed
Chris
mach1rob
Post by mach1rob »
Yes, does kind of make you wonder how they think they can charge so much, one reason I will only use them for stuff I can't get from a factor and T series exhaust manifold gaskets.
Dorset_Clive
Post by Dorset_Clive »
One thing I can tell you...not a single garage between the M25 and Cambridge had one on Saturday night :(
The bulb failed in the rally car on Saturday evening on the way to a rally and as we're timed to the nearest minute on this even we didn't need to bother with the posh expensive rally clock...big mistake that was :( In the end, I had the trim panel in my lap on the drive up, with the bits box laid out on the back seat trying to jury rig a 5w sidelight bulb to fit :roll:
Clive
"Paint your life in bright colours"
Sir Robin Knox-Johnson
matthewsemple
Post by matthewsemple »
Devon-rover wrote:£0.89 I feel sick! X-Part want our business at what expence Rip-off sods
I had a similar problem with a temperature sensor. Not with X-Part but with a Rover dealer who wanted to charge me £36 for one - even though they are only £9 from X-Part :x
Gibbo214
Post by Gibbo214 »
i presume using a blue bulb would not make the clock illuminate blue? anyone got any ideas on this or have changed the illumination colour of their clock?
matthewsemple
If the original light is clear then a blue light would make it a mucky colour - mixture of blue and orange.
