That's the thing looking at the head there isn't anything to be modified that I could see. Your not the first person to say something about the oil restricting thing. I've studied both the before and after pics of both sides of the block and head and there is nothing that looks as if it needs modifying.roverman1 wrote:I really feel for you Kain i really do, this is soul destroying. When you replaced the gasket did you do a modification to the oils feed on that corner of the head, I'm sure I've read somewhere that there is some modification that needs to be done on the M and T series to try and cure the oil leak.
I would very much doubt that the block would have a crack, the T series suffer the exact same problem even after a gasket swap.
My reason behind there being a crack of some kind is that it takes about 3-4 mins for the block to warm up and then the oil starts pouring out of the same place as before. That to me means a crack as it opens up the warmer the engine gets and the crack opens up.
