Alarm light speed 216 Coupe (Honda)
Smiffie
Post by Smiffie »
When the alarm is armed how fast should the red light flash? mine flashes once per second, is that normal?
Re: Alarm light speed 216 Coupe (Honda)
Seems about right.
The blink much faster when arming I seem to remember
yep about right unless you open the door then it should blink a lot faster.
Julesmat50
Post by Julesmat50 »
Smiffie wrote: Mon Oct 15, 2018 8:30 pm When the alarm is armed how fast should the red light flash? mine flashes once per second, is that normal?
Yep. Mine does the almost same, blinks very rapidly when arming, 1 second pulses when armed but a solid red when the door is opened using the key, rather than the fob. Anything else sets the alarm off :)
Smiffie
Post by Smiffie »
Thanks.
