Search found 972 matches
- Sat Dec 13, 2025 6:54 pm
- Topic: Track Rod End - Split Pin or Nylon Lock Nut
Re: Track Rod End - Split Pin or Nylon Lock Nut
Do you have a cunning plan of how to preserve the current tracking setting?
- Fri Dec 05, 2025 1:27 am
- Topic: unstable idle
Re: unstable idle
The yellow vacuum tube goes to a thermac switch (valve) in the air filter box. There should be another (probably red) coming from the other side of that vacuum switch, then going to a nipple on the inlet manifold. The vacuum from that switch operates an actuator at the air inlet, to draw warmed air ...
- Wed Nov 26, 2025 11:57 pm
Re: unstable idle
Have a look at this thread: https://rover200.org.uk/forums/topic/16491
- Fri Oct 24, 2025 10:24 am
- Forum: The Gallery
- Topic: Rovers at East Kirkby July 2005
Re: Rovers at East Kirkby July 2005
Is there a SU carburettor factor involved?
- Fri Oct 10, 2025 1:09 pm
- Forum: The Lounge
- Topic: ARO 'counter factual' article on the Rover/Honda relationship
Re: ARO 'counter factual' article on the Rover/Honda relationship
I like this positive view of the Honda relationships prospects, and it does tie in nicely to BAe being the ultimate villains. After all, a lot of the mess BMW inherited was a result of BAe's underinvestment previously. I tend to home in on George Simpson specifically. Although he came from Leyland ...
- Mon Sep 22, 2025 11:36 am
- Topic: 3 door 214Si 1992 - Panels
Re: 3 door 214Si 1992 - Panels
I'm in a similar position with my 1991 3dr 214S.
When you become a Club member, you can access this page to qualify for a discount:
https://rover200.org.uk/members-login/m ... panels-r81
- Mon Aug 11, 2025 6:13 pm
- Topic: Rover 220 Coupe throttle body potentiometer
Re: Rover 220 Coupe throttle body potentiometer
I recognised JZX as a prefix from various A-R carburettor parts and other fuel system components.
So it's appropriate that Burlen list them as in stock, as Burlen now looks after SU carburettors.
https://sucarb.co.uk/potentiometer-2.html
- Fri Jul 18, 2025 7:48 pm
- Topic: Rover lock barrels
Re: Rover lock barrels
Been a while since I had mine (from a R8) apart to fix a non-closing flap, but recall it was marked 'Valeo' on the casting. If yours is similar, and particularly if the key blanks are listed as common to the MG's that I'd say they're likely enough to be the same component to make it worth your while...
- Sun Jun 15, 2025 10:39 pm
- Topic: Rover 45 heater always warm
Re: Rover 45 heater always warm
A good start would be to locate the heater control valve, and check that its operating
lever travels reasonably freely over its complete sweep.
- Sat Jun 07, 2025 12:44 pm
- Topic: gaiters an trailing arm rubbers
Re: gaiters an trailing arm rubbers
A story I took notice of at the time was that GKN Driveline was aggressively bought out by a
vulture capitalist outfit a few years ago. They're unlikely to give a toss about maintaining
quality over short-term profit.
