Search found 14 matches
- Wed May 20, 2026 4:29 pm
- Topic: power steering
Re: power steering
Thanks for the reply, will try your suggestions over the weekend. Mine has the honda engine so hope its not the pump!
- Tue May 19, 2026 4:52 pm
power steering
power steering on my 216 coupe is very heavy compared to other coupes. tyres are correct pressure and no fluid leaks. any ideas guys
- Sun Sep 21, 2025 9:45 pm
- Topic: rover wheels????
Re: rover wheels????
thank you for your reply
- Sun Sep 21, 2025 9:18 pm
rover wheels????
does anyone know if this is a rover wheel
- Wed Sep 17, 2025 7:22 pm
- Topic: 1995 216 instruments
Re: 1995 216 instruments
Thanks fo the replies, my fault i wasn't expecting a speedo cable. Wish i had read your answer before i removed cable from gearbox end, still looking for the clip. When i find it can i attach to the cable first, before pushing cable into the box. Thanks again
- Tue Sep 16, 2025 10:08 pm
Hi all, Trying to replace some blown bulbs in the instrument cluster. surround is off, 4 screws removed from dials but it only pulls out a few inches, not enough to dis connect wiring plugs. Am i missing something
- Sat Jul 12, 2025 11:05 pm
- Topic: Vin number
Re: Vin number
hi Coupe fan, thanks for your comments. Are you saying that the honda engined coupes, even auto ones, were only made up till June 1995
- Tue Jul 01, 2025 11:34 pm
- Topic: Vin number
Re: Vin number
i was originally trying to find a build date, but hit a wall when the vin number kept coming up as a 1981 car, not possible on a coupe. still trying to find the build date
- Wed Apr 05, 2023 5:46 pm
- Topic: drivers door lock
Re: drivers door lock
door card is off. rod from handle to lock is my main problem. don't want to use a drift and hammer in case it won't go back togetherMr Teddy Bear wrote: ↑Wed Apr 05, 2023 2:46 pm Buy some plastic trim tools & remove the door card. try to be gentle when prising the card away from the plastic locating dowels in the door frame.
- Tue Apr 04, 2023 10:48 pm
drivers door lock
1998 216 coupe. door lock button has jammed in the locked position, door only opens from inside handle, cable controlled, can't seem to release the rod from door handle to lock so i can get lock out to have good look at it. Any advice would be very helpful . thanks
