Search found 104 matches
by SteveB
Mon Aug 03, 2026 5:50 pm
Topic: Three little words: “While I’m on…”
Re: Three little words: “While I’m on…”
We've been quite lucky here in the North East, not had the extreme temperatures you've had further South. Having said that, we had a few very humid days in the high twenties and I struggled to get much done. Might have something to do with growing old :)
Good luck with the R3.
by SteveB
Sun Aug 02, 2026 8:50 am
okay, technically it’s four words but anyway… you know how it is. You plan to do a job on the car that, somehow becomes a lot bigger. For example, the car was about due a timing belt. It makes sense to replace the water pump at the same time so, “while I’m on”, I might as well do that. This means dr...
by SteveB
Wed Jul 29, 2026 5:56 pm
Topic: Replacing the High Level Brake Light - 218iS R3
Re: Replacing the High Level Brake Light - 218iS R3
The download section's a brilliant resource, there's loads of useful stuff in there. I've used it a few times, saved quite a bit of trial and error!
by SteveB
Mon Jul 27, 2026 6:24 pm
In the downloads section - '200 (R3) Workshop Manual - Electrical'. Section 20 shows how to remove and refit the light, looks like you have to remove the spoiler so you're on the right track.
by SteveB
Fri Jun 19, 2026 6:55 pm
Topic: Rover 214Si 3 Door Rubbing Strip Removal
Re: Rover 214Si 3 Door Rubbing Strip Removal
The short piece on the front wing - exactly as Plodder says – unfasten the wheel arch liner to gain access. While you’re in there, it makes sense (if you don’t already do it) to clean out the silt and debris that collects inside the bottom of the wing. As for the rear quarter panel, it’s a lot of ye...
by SteveB
Wed Jun 17, 2026 9:29 am
Spot on. I know it's a bit of a faff removing the door trim, and (from memory) a bit of a faff removing the trim panel beside the rear seat, but it's well worth the time and effort to avoid damaging the strips. Anyway, while the trim panels are off it's an ideal time to do some rustproofing!
by SteveB
Wed Jun 17, 2026 9:06 am
Topic: 420 Si cutting ignition every once in a second
Re: 420 Si cutting ignition every once in a second
I've only once had a crankshaft sensor fail (on my 1995 R8). There was nothing intermittent, it just died - the car was running fine, switched it off, went to restart and nothing. I have had a similar issue with the car literally cutting out for a fraction of a second. It got much worse very quickly...
by SteveB
Sun May 17, 2026 10:00 am
Forum: The Lounge
Topic: Humour
Re: Humour
My dog once ate some Scrabble tiles...
He kept leaving little messages all over the place.
by SteveB
Sun Apr 05, 2026 10:22 am
Forum: The Lounge
Topic: Breathalyised.
Re: Breathalyised.
One evening (a few decades ago), I was driving my Triumph 1500 along the Old Durham Road in Gateshead when I was pulled over by one of the boys in blue. He asked if I’d been drinking, as my driving seemed a bit erratic and I was wandering around a bit. I was surprised to hear this and no, I hadn’t b...
by SteveB
Tue Feb 17, 2026 7:36 pm
Forum: The Lounge
Topic: Reduce Vehicle Excise Duty by 50%
Re: Reduce Vehicle Excise Duty by 50%
Exactly. For the same tax you could be running a 2 ton 6.75 litre Royce, which is crazy. The 1549cc changeover point does seem a bit arbitrary.
From the VED point of view there's no incentive to keep a 1.6 on the road, so hats off to all those who do.
