Search found 8 matches
by Geo_coupe
Sun Jun 10, 2012 8:33 pm
Topic: How to refurb black crackle finish on cam cover ?
Re: How to refurb black crackle finish on cam cover ?
Rub some Vaseline on the raised bits, spray the rocker cover then wipe the Vaseline off, works a treat.
by Geo_coupe
Tue Apr 24, 2012 8:51 pm
Topic: 216 GTI DOHC TC - stock VS upgraded questions
Re: 216 GTI DOHC TC - stock VS upgraded questions
Sorry for the late reply mate, the clutch and flywheel were a straight swap on my d16 sohc, cant say 100% if its the same on the twin cams but I know the gearboxes fit either engines...
by Geo_coupe
Sun Apr 15, 2012 3:29 pm
Forum: Events and Meetings
Topic: Pride Of Longbridge Rally 2012 14th April
Re: Pride Of Longbridge Rally 2012 14th April
That's a good pic of my gti roverman1 (j49 tuh) :D
by Geo_coupe
Sat Apr 07, 2012 6:38 am
Heres a link to a clutch and flywheel combo i bought a few years ago, clutch isnt too heavy and never had any problems slipping http://www.ebay.co.uk/itm/F1-STAGE-2-CLUTCH-KIT-FIDANZA-FLYWHEEL-1989-1991-HONDA-CIVIC-CRX-1-5L-1-6L-SOHC-/160713527347?pt=Motors_Car_Truck_Parts_Accessories&hash=item2...
by Geo_coupe
Thu Apr 05, 2012 10:20 pm
On the subject of clutches, its worth looking at getting the bigger.flywheel from a vtec civic (for a 212mm clutch iirc) and then that opens up lots of options for aftermarket Honda clutches
by Geo_coupe
Tue Mar 06, 2012 4:58 pm
Topic: new PGMFI ECU and now the rev counter is flickering. Why ?
Re: new PGMFI ECU and now the rev counter is flickering. Why
It could be a failing igniter in the dissy or rust on the connections of the ignition coil causing the flicker, im sure ive also read in the past of people having these symptoms prior to the main relay under the dash giving up the ghost due to dry solder joints.
by Geo_coupe
Wed Dec 13, 2006 9:19 pm
Topic: Hi all!
Hey Marc, its definately a Honda engine, D16A6 SOHC job. think the coupes had them up to about a '96? i may be proved wrong on this though, but ive seen a few hona engined ones in the scrappy lately with all the scavenging ive been doing!!
Cheers
G
by Geo_coupe
Wed Dec 13, 2006 8:57 pm
Topic: Hi all!
Hi all!
hey people thought id better introduce meself. im driving a 216 honda engined coupe at the moment, im wanting to start modiying it but everytime i get round to it something else breaks!! (its laid up with a snapped driveshaft at the mo!!) So no doubt ill be back looking for some technical help in th...
