Search found 61 matches
by derbylad
Mon Aug 27, 2007 8:59 am
Topic: hydralic clutch
hydralic clutch
hi i was wondering if anyone knows how to bleed the clutch on the rover400.has i need to replace my gear box and driveshafts.
by derbylad
Mon Aug 20, 2007 9:59 am
Topic: can some one help?
i have got another problem on the car now *laughs*
its a loud rumbleing noise coming from the front end when i am driving but when i press the clutch in and the revs drop to 1000 it stops but as soon as i hit 2000+ revs it starts again *laughs*
by derbylad
Thu Aug 02, 2007 6:06 am
Topic: timing settings
thanx for your help ill have a look at that then get back to you dave
by derbylad
Wed Aug 01, 2007 9:58 pm
yea it runs and revs fine and normally the revs sit on 1000 revs when warm on tick over and when its cold it is t 1500 revs
by derbylad
Mon Jul 30, 2007 10:29 am
no its just struggleing to clim hills and you have to give it quiet a bit of revs when you move of *laughs*
also there is a loud clicking coming fron one of the injectors
by derbylad
Sat Jul 28, 2007 12:01 am
timing settings
hi i was wondering if anyone has got the timing settings for a 414 16v engine.the car is running fine but when i go up hills i have to drop down to 2nd or 1st gear.so i think it might be my timing *laughs*
by derbylad
Mon Jun 18, 2007 6:58 pm
Topic: water leak
thanx for your reply ill have a look when it gets dryer *laughs*
by derbylad
Thu Jun 14, 2007 9:35 am
Topic: water leak
water leak
i have got a puddle of water in my boot but i cant seem to find where its coming from can anyone help me please
by derbylad
Tue Jun 05, 2007 9:13 am
Topic: can anyone help
In the end i striped all the back end down and it was the main arm that was slightly bent.So i have had to buy a new one and put it on so now its sitting right at last *laughs*
by derbylad
Sun Jun 03, 2007 9:06 am
thanx for your help i have had a good look underneath and there doesnt seem to be anything bent so ill take it into the garage on monday and see what they say *laughs*
