Search found 22 matches
- Mon Nov 09, 2020 5:00 pm
- Topic: Windscreen wiper not stopping
Re: Windscreen wiper not stopping
Is that the brown relay that fits behind the centre console I have already replaced this about 18 months ago due to starting problems and it’s been fine since or is it a different one? Thanks Beverley
- Mon Nov 09, 2020 3:01 pm
I have a Rover 416 1993 model when I turn the windscreen wipers to the off position the wipers are still running on intermittent has anyone else had this issue?
- Mon Mar 04, 2019 7:25 pm
- Topic: Windscreen wiper stuck
Re: Starting problems again!!
Im off work tomorrow and Wednesday but need the car for Thursday is that any good? My son could bring it tomorrow morning? I’ve been to your house once before when a few members were helping clear your garage out
- Mon Mar 04, 2019 6:55 pm
It is the Honda 1.6 engine what is the Mfu? Thanks Beverley
- Mon Mar 04, 2019 6:41 pm
Hi thanks for your replies the Rotor arm was replaced not that long ago but the RAC guy did say there was a tiny bit of scoring on it my hubbys just put jump leads on it and it started within 2 seconds even though the battery was showing it had 12.3 charge in it before he put them on it has done thi...
- Mon Mar 04, 2019 4:50 pm
I have a 1993 River 416 1993 and when I turn the wipers off it’s staying on intermittent?
- Tue Dec 05, 2017 1:00 pm
- Topic: Electric sunroof for 416 converted to manual
Does anyone know if you can convert an electrical sunroof for a 416sli to fit a manual sunroof?
I've been given an electrical one but mine is manual will it work?
- Sun Oct 29, 2017 4:48 pm
- Topic: Starter ptoblems
Re: Starter ptoblems
Hi Dist
Thanks for the offer its nice to know there's someone local who can help me but don't worry I won't bother you unless I have to. The relays back in situ and its started 7 times on the trot so fingers crossed it just needed a good clean I'll know better tomorrow when I use it for work.
- Sun Oct 29, 2017 2:59 pm
My sons having a go at cleaning the auto relay switch all solder joints look fine the next step is the starter motor but it looks like I would have to order it anyway. If I order one would you be willing to fit it for me obviously I would pay you but also it would be good to get another opinion?
- Sun Oct 29, 2017 2:27 pm
In response to Duncan the new rotor arm hasn't solved it. My son has just cleaned the idle air control valve still not solved. No we haven't changed the starter motor but getting really fed up now so going to see if I can get from our local europarts but my sons not confident about changing that. An...
