My 92 216 has the same problem.
Relay I believe is drivers side A pillar up under the dash
Search found 20 matches
- Fri Sep 01, 2023 9:34 am
- Topic: Windscreen wiper not stopping
- Sat Feb 11, 2023 8:46 am
- Topic: Sealing tailgate hinges after adjustment
Can I loosen the hinges to adjust tailgate and then re-seal around the hinges? Or do they have to be fully removed to apply sealant between the hinge and car body?
- Sun Dec 11, 2022 9:43 am
- Topic: R8 Cars with Infrared fobs - future support?
Re: R8 Cars with Infrared fobs - future support?
Would it be possible to fit this on a 1992 car which doesn't have a factory alarm or remote central locking?
It does have central locking via the key blade though
- Sun Dec 11, 2022 9:37 am
- Topic: 5 door R8 water in boot
When I first got my 216 GTI the boot was full of water. Most of the water was coming in due to a bent and seized tailgate hinge causing the tailgate to sit high. I've replaced and sealed both hinges and adjusted the tailgate (as best as I could at the time). Water is still getting in. It is NOT the ...
- Fri Mar 04, 2022 7:12 am
- Topic: geabox oil
Re: geabox oil
The pg1 uses MTF94 in all the 1995 onwards Rover’s ownedMr Teddy Bear wrote: ↑Sun Apr 29, 2018 6:59 pm Eh?
Well I wouldn't, the R65 with the 1.4 K Series takes 2 Litres of of Total BV that has been superseded by Total Transmission Gear 8 SAE 75/80 which is in mine now.
The Honda PG1 uses engine oil and should br drained every 24,000 miles
- Fri Mar 04, 2022 7:03 am
- Topic: 216GTI gearbox oil
216GTI gearbox oil
Hi, can anyone tell what oil the 216gti (Honda engine) takes?
- Thu Oct 21, 2021 8:44 am
- Topic: Membership number?
Membership number?
My car insurance has asked me for my membership number to this club to provide a discount, does such thing exist?
- Fri Jan 22, 2021 12:58 am
- Topic: REFERENCE SHOCK ABSORBERS
- Mon Jul 09, 2018 10:24 pm
- Topic: 216gti tailgate misaligned/higher than roof
Re: 216gti tailgate misaligned/higher than roof
I think this should display the pictures
- Mon Jul 09, 2018 10:16 pm
