Looks like a flock of Seagulls have shat on it
Search found 193 matches
- Wed Feb 28, 2024 9:31 pm
- Topic: Welded roll bar bracket
Re: Welded roll bar bracket
Is that Welding ?
- Mon Jan 01, 2024 7:39 pm
- Topic: K Series Cams
K Series Cams
Hi All Doing an Engine swap & the replacement engine is older than the blown one. It's a 2001 Rover 45 1.6, the replacement is from a 1998 Rover 216, obviously the replacement isn't the Wasted Spark K Series so doesn't have the CPS Lobe. Question is can I just change the one Cam from the blown e...
- Mon Sep 25, 2023 9:15 pm
- Topic: coolant blowing out of the header tank cap
Re: coolant blowing out of the header tank cap
Father in Laws 214 Cabbie did this a few years ago, luckily it was only the rubber seal on the expansion tank cap. Replaced the seal & it hasn't done it since
- Tue Jul 11, 2023 6:23 pm
- Topic: VVC into 1.6 Cabriolet
Re: VVC into 1.6 Cabriolet
It's going to get a damn good clean, paint & polish before it gets anywhere my show Cabby
- Sun Jul 09, 2023 6:22 pm
I had a more detailed examination of the wires today and the smaller connector plugs all appear the same. The large Blue one that I'm assuming is MGF Engine to Body loom connector is a different shape from the R8 Grey one. I have Auto Electric knowledge & suppose the Blue connector wires could b...
- Wed Jul 05, 2023 7:15 pm
More confused now :laughing2 What I've got is Engine https://i.ibb.co/vcb9v2n/20230705-191231.jpg VVC Loom connectors https://i.ibb.co/v1cK940/20230705-191243.jpg K Series Loom connectors https://i.ibb.co/8dQ2nKL/20230705-191453.jpg I have ECU, Fob & all boxes from 1998 MGF. Where does the engin...
- Tue Jul 04, 2023 8:40 pm
- Topic: Cabriolet hood
Re: Cabriolet hood
Who ever does it you are better off checking rear rail and side brackets at least get them blasted and coated a new hood is something that should be right , you don't want a rusty frame etc on a new hood . Good advice, I was lucky enough to have a spare set of retainers & rear bar that I preppe...
- Tue Jul 04, 2023 8:33 pm
OK, that may be where this idea grinds to a halt !
- Mon Jul 03, 2023 7:35 pm
Re: Cabriolet hood
I did mine myself, it was relatively easy & took me about 6 hours. Which ain't bad having never done one before. Mind you I am a Bodywork Technician by trade so have an unfair advantage :laughing2 Luckily who ever replaced the roof previously had the forethought to use Stainless fixings, so I di...
- Mon Jul 03, 2023 7:22 pm
You may come into a little difficulty in using the MGF engine loom. Im not 100% but I think it might be a little different in terms of location of connectors to where they need to be. You might be better of sourcing one from a VVC Coupe, 200 BRM or 200VI (all of which are quie rare cars now.....) A...
